I was trying to install my neuspeed upper strut tie bar when the upper arm assembly slipped down out of the frame because I was trying to get the bar over it. Now I can't seam to get it back in.
I have it jacked up and the tire removed, the back of the arm assembly is stuck on the springs so I can't move it upwards and even if I could it doesn't look like i could force it back in. I need help, what should I do?
Here is a picture of my problem. What I circled is the part that has slipped out of the frame and is dangling down below. Please help
I circled the holes it needs to go into, and the bar that is getting caught on the springs. Should I remove the parts (stabalizing link maybe?) and get them screwed in up top then try and connect it back to the upper arm assembly? Plz help!!
