Can anyone tell me what it used to form the gasket between the upper radiator hose and the engine? There is the upper radiator hose mount on the engine and that mount attaches to the engine and there is no factory gasket like the one used for the thermostat housing....so, something has to be used to make the seal between the hose mount and the engine....any ideas what is supposed to be used to mount it? Is there a particular sealant?
I have a D16Z6 engine...if that matters.
Also, what sort of solvent or cleaner is used to clear the engine surface before you apply the gasket sealant? I what the surfaces to be smooth and clean so that the sealant makes a good seal and doesn't leak....
