Using a clay bar is probably one of the most beneficial yet often understood steps to proper paint care. It's fairly quick, very easy, and extremely safe. Here's how to do it:
Regardless of where you live, your paint's finish is subject to a variety of damaging contaminants. Acid rain, bird droppings, metal particles, brake dust. All of these present a danger to the integrity of your paint.
You may not necessarily see them, but you can definitely feel them.
Mothers® Clay Bar is a great product for getting rid of paint fouling grime.
First, remove the clay bar from its wrapper, then knead and flatten the clay in the palm of your hand.
Starting with a cool, clean surface, spray the Showtime® Instant Detailer liberally in a sweeping motion to lubricate the small area that you're gonna be working on, it's about two square feet.
Lightly glide the clay across the lubricated surface. You may feel an initial resistance, and even hear the contaminants as they're being removed. Now continue this process until the area feels completely smooth, and the clay glides easily.
Now between panels, knead and fold the clay bar back onto itself to refresh the working surface. Always ensure the paint surface is thoroughly lubricated when using clay.
Using a soft microfiber or terry cloth towel, dry off any excess Instant Detailer and move to the next area to be clayed — re-knead the clay bar for each new section to maintain effectiveness.
Plan on re-waxing the finish after using the Clay Bar.
You've heard about clay bars—professional detailers, body men and your car buddies all talk about how they work. Now use the clay bar everybody wants. Created to remove the particulate debris and contaminants that washing and polishing can't, our exclusive Clay Bar System will remove embedded grains of metal, tree sap, airborne environmental deposits and paint overspray. Better yet, our clay bar isn't hazardous to your paint—it's just firm enough to pick up the bad stuff, without being too aggressive. Use Mothers® Clay Bar to get rid of paint fouling grime and pave the way for complete waxing.
Mothers® is known worldwide for its premium-grade polishes, waxes and cleaners and offers a broad array of finish care products under its California Gold®, FX, Reflections®, PowerBall®, Marine and Professional lines. Go to Mothers® Polishes·Waxes·Cleaners for information on all of these products, along with a host of car care tips in the online Mothers® Detail Guide at MOTHERS® Polishes·Waxes·Cleaners and the Wax Forum at Wax Forum
I've personally used mothers clay bar, but I don't think its much better than a good can of elbow grease and some cleaner wax or some scratch/haze remover.
While I do agree it gets it done with much less effort in most cases, just gimme some haze remover and im good.
Anyone else used this product before?
For clarification, Clay Bar is not intended to replace paint cleaners and polishes and does not remove surface defects, but it is an important first step to provide a clean slate without removing paint or clearcoat.
You can clay a car without much elbow grease, which should also be an indicator that it is easier on your paint.
If the paint finish requires it, certainly do use polishes to remove swirls, oxidation or other defects before waxing.
Remember that you only have so much clearcoat, and to polish away surface contaminants is unnecessary when you can remove those contaminants safely with clay bar and without worry about removing clearcoat.
Clay is great for cars without a clearcoat as well, but virtually all modern cars come from the factory with a clearcoat, especially those with metallic colors.
Generally speaking, an average daily driver might only need to be clayed 2-3 times a year, but it will vary greatly depending on environmental exposure. While it is a precursor step to waxing, it's not required every time you wax, though you should inspect the surface for the need to clay. Sealed-in contaminants can damage your paint.
