Well i did them awhile ago, but i did shitty job.
So i am going to it again. How are the spray paints from local shops. Duplicolor(?)
I bought some paint from shop last time, it cost me 60.00 because they had to mix the paint
Feed back is very welcomed.
thanks much.
I've used duplicolor for about three years now, I've finally got the technique down, they're pretty good quality and have a fantastic drying time (48hrs till compounding can be done). The main thing is a smooth primer coat, two color coats, and an good amount of clearcoat, clearcoat is what helps prevent chipping and allows you to wet sand and compound to get a high gloss, I usually do anywere from 3-4 coats. Make sure that you use a tack rag after the color coat is dry and before using clearcoat, when using a mettalic color, they tend to leave a grainy residue on the paint.
Good luck.
Discussion Starter #4
well duplicolor does not have my color.
98 cord sedan. Metalic silver?
