vafc+check valve???
will a check valve werk with a vafc with dsm 450's to eliminate the CEL for boosting more than 10psi? I read in a post about the vafc hacks and they say that you dont need to check valve with the vafc, but then you get CELs when boosting 11+psi...
thanks
dan
you should already be using the missing link so ur map doesnt see boost! that may be why ur getting the CEL
pull the cell code to see what code ur getting.
the vafc will only richen or lean out ur fuel system at certain rpm.
