Looking for experienced "B" motor builders. Got a question for you. I'm building a frank B motor, B20b block, B16 head. I'll be cutting the seats 3 to 5 angles. Have already ground the 45s on the valves. Sources tell me to back cut the intakes(30deg.), but no one has been able to say if it will help or hurt on the exhaust? What about another angle after the 45 on the on either intake or exhaust? Anybody got any flow bench time on these motors? I've blended the bowls, smoothed out any casting seams, gasket matched them, and sharpened the split on the intake. I'm now in the process of narrowing the guides and smoothing out that area. I'll finish that with some Splash Zone epoxy. The larger bore will require some de-shrouding also. Any body out there know what angles these heads like? Thanks, Smitty
