9400rpms said:
no, thats the biggest load of crap i've heard ever..show me in stock form why honda put it there, because it isn't for emission purposers..
um, yeah it is.
the PCV technically is an emissions control system. By law, a catch can venting to open atmosphere is not emissions legal, as it expels crankcase gases into the air... of which include HCs and CO.
same reason why not having a gas cap is not emissions legal... same reason you have a charcoal canister, same reason for a lot of things on a car.
It's made that way from the factory because there's no other way to do it while staying emissions compliant. For it's purpose, it works. It is not 'good' for performance, it's good for practicality and legality.
The PCV system is there because as your engine goes through its four stroke cycle, it builds pressure inside the crankcase. The pressure has to be released somewhere, or you'll experience problems such as George's recent issues. For this reason, they've made the PCV system. Because of emissions control laws, they are unable to vent the crankcase pressure to the atmosphere, and are therefore forced to vent it somewhere else. The most logical and economical place is back to the intake, where it can be burned through the combustion cycle, and exhausted through the tailpipe and catalytic converter, thus virtually eliminating whatever emissions might have occured through venting the crankcase.
And one other thing... the PCV system is in no way like a catch can system... the catch can is designed to eliminate the flow of spent crankcase gases and oil through the pcv system and into the intake charge. the stock PCV system allows small amounts of oil, and all spent gases, to go through the valve.
while you might not be getting oil in it, Unless the catch can is vented to open atmosphere, you're still putting dirty, previously spent gas into your combustion chambers... this gas takes up space away from the pure air/fuel mixture, and lowers combustion efficiency due to the gases low oxygen content.
If you're not going to vent to open atmosphere, a catch can is virtually a complete waste of your time and money.
