Good point :tuSnoopy said:all this would do is allow you to change the vtec x-over. you cant change any of the ignition or fuel maps. bad idea.
It is absolutely possible. Just as it is possible to put VTEC on a WOT switch (like nitrous). There is nothing stopping you from controlling VTEC engagement by whatever means you want, as long as you understand where voltage needs to be applied.hondahubby said:Why would you want to do this? When VTEC "turns on" (as you put it) the computer engages some mechanical solenoids that causes a cam profile more suited for the higer rpm range to be used. (it is quite clever the way it does it, I encourage you to read up on it)
The computer knows when to start using the different cam profile far better than you ever could.
I would suggest you let the computer keep control of that.
Plus, I doubt it is even possible and someone was just pulling your leg.
Ok, I will go with that.Nathan123 said:It is absolutely possible. Just as it is possible to put VTEC on a WOT switch (like nitrous).
That's cool. I was unaware that it could be done as well and I was just curious as to why someone would want to do it. Snoopy's post clarified it for me with his last post that suggested you would want to do it if you had an aftermarket cam. That makes perfect sense.BurntRubber87 said:Hondahubby, He asked if it could be done..I told him. Maybe he wants VTEC lower, maybe he wants VTEC higher. Its not my business if he wants to, and that whole big spiel about how VTEC works...everyone knows. It isn't some divine info that only a few know about.
i suggest waiting for a good price on a p28 so you can get the most power out of ur EX motor. using a non vtec ecu is not the way to do it.weewoo said:the reason i asked this question is becaues i have a d16z6 but with no vtec,
i have my stock p06 ecu and i cant find a p28 for a decent price, so if i were to do this i would have vtec, my swap is all done the only missing part is the vtec,i was also told i could do it with a vtec controller but right now im on a tight budget and will do the cheapest way out even if it takes to get a p06 does anyone know where i can get one for cheap???
