Hi,
I have a classic mini with a b16a2 obd2 engine in it. It is hooked up to a chipped (p28 i think but there are no stickers on the ecu) obd1 ecu using an Integra TYPE R dc2 engine harness and a custom made loom from minitec which plugs into the strut top plugs of the integra harness.
The car runs fine apart from vtec not engaging.
The chip in the ecu has VTP/VTS, temp check, speed check and knock disabled
I have tested the tps and thats reading .5v at idle and 4.45v at WOT
I am not using a honda gauge cluster in the car.
The vtec solenoid clicks when 12v is fed to it
Vtec does work if forced using a switch
There is no Vtec oil pressure switch on the engine or a wire going to the pin for it on the ecu.
I have tried jumping the pins for the vtec solenoid and the Pressure switch together with no sucess.
No voltage comes from a4? when at the vtec engagemant point.
I have tried to fit an MIL light but cant get it to illuminate, checking with a voltmeter there is 4.5v coming from the MIL wire when the ignition is on, and the voltage doesnt change when grounding the SCS pin D6? so i cant read any codes if there are any.
Ive searched the forums and tried all the above.
Anybody got any ideas?
Thanks
Richard.
Thanks
Richard.
