I was throwing a code for vtec pressure switch...my car was cutting off at 6500 rpm's I switched the pressure switch out and car worked fine for a day reving out to 8200 rpm s now today it is cutting off again at 6500...its a 95 gsr any ideas?????
Did you check your oil? If you are low on oil it will always cut out. Also do you have a VAFC or a fields SFC or any kind of piggyback tuning device? My fields is giving me problems, i got the same code as you but i just shoved the loose wires in the harness and it's ok now.ShiftedLS said:I was throwing a code for vtec pressure switch...my car was cutting off at 6500 rpm's I switched the pressure switch out and car worked fine for a day reving out to 8200 rpm s now today it is cutting off again at 6500...its a 95 gsr any ideas?????
