my 1994 integra vtir has lost boost at 5000 and beond, with the low rpm cams it drives fine when trying to accerelare past 5000 it does not boost like before then as it gets higher it looses acceleration and sounds as if engine is strugling........
Your engine WAS cammed for natural aspiration. NOT turbo. Therefore the overlap that was in place to get better N/A performace is ruining your boost as its dumping it down the exhaust, probably causing a lot of problems with AFR mix as well.my 1994 integra vtir has lost boost at 5000 and beond, with the low rpm cams it drives fine when trying to accerelare past 5000 it does not boost like before then as it gets higher it looses acceleration and sounds as if engine is strugling........
"clunk" i never good :lmaoWhat do you mean it went clunk.
