Basically warm it up first if its cold outside!!!..151 Proof said:You can drive your car just fine without warming it up, just don't rev it past 3000 rpm, it will actually warm up quicker that way anyway. All you are really doing when you warm you engine up is heating up the oil in the engine so that it runs smoother (as you know heat will cause the oil move around faster than it would if it were cold). Think of it this way, go get a bottle of cold syrup and pour it, see how slow it flows, then put that same bottle in the microwave and pour it, it will pour out a lot smoother when it's heated up than cold.
Only if you wanna waste gasasiancivic said:Hey what about cooling/warming down ? I mean on and off we were told that n/a cars dont need turbo timers, but it's really logical that we should let the engine run a while longer especially after a hot/long drive, to let it cool down a bit with the coolant and fans and engine oil running, I mean just think about it, the engine will be very hot after a long drive and if you just let everything stop there (engine oil,coolant etc) wouldnt that be bad for the engine?
Mmm... microwaved syrup... :laughy:151 Proof said:You can drive your car just fine without warming it up, just don't rev it past 3000 rpm, it will actually warm up quicker that way anyway. All you are really doing when you warm you engine up is heating up the oil in the engine so that it runs smoother (as you know heat will cause the oil move around faster than it would if it were cold). Think of it this way, go get a bottle of cold syrup and pour it, see how slow it flows, then put that same bottle in the microwave and pour it, it will pour out a lot smoother when it's heated up than cold.
You should let it cool down, for like a minute or two but it's not as neccesary as it is on a turboed car because there isn't as much of a heat build up.asiancivic said:Hey what about cooling/warming down ? I mean on and off we were told that n/a cars dont need turbo timers, but it's really logical that we should let the engine run a while longer especially after a hot/long drive, to let it cool down a bit with the coolant and fans and engine oil running, I mean just think about it, the engine will be very hot after a long drive and if you just let everything stop there (engine oil,coolant etc) wouldnt that be bad for the engine?
Buddy... Its not that we let a turboed car stay on after a drive because of heat build up... Its because the tubo spins really really friggin fast, dont quote me but its in the 13 000 rpms range, i dont remember exactly (i know im gonna get a reply tellin me im wrong) So if you were to turn off your car after its going that fast, u loose oil pressure and the oil that was being used on the turbo rod thing (i dont remember the term) to keep it lubricated is no longer there, therefore providing no protection to something thats still spinning really fast... Ill give you credit enought to say that you know what may happen next...151 Proof said:
