1 - 14 of 14 Posts
I got a V-Force last night and hooked it up.
I put a rear section exhaust and an intake on a hour before installing a V-Force.
Installer followed by the manual, so there was no problem while intalling. (I hope so.)
I was going to my house on local way (I think I drive w/ no problem like 30miles), then engine check light just came on and my car is just stalled.
WTF!
So I parked my car in gas station and I tried to reset ECU.
Yeah...of course engine check light went off, but I'm still worried.
I drive my car today like a few miles and there is no problem now.
Hmm...my exhaust sound is little bit different compared to last night.
Less loud I think. (Much deep sound)
Do I have to put it off on my car and sell it? or just keep it?
Help me out.
Thanks.
I have been wondering, what is a jet v force?? i have seen a few post on that.. can you tell me what it does, or is that a new exhaust or what
Psyk0tic said:
I noticed your car has Teg leather seats. Do you have the 2dr or 4dr rear seats?
I think he's lookin' for 2-doors...
I know what is wrong!!!
I used to have the v-force on my 00 ex. I know all about the check engine light shit. You need to go back and heat shrink and solder all of your wiring!!! If the ecu picks up any fluctuations in voltage to the MAP sensor....check engine light and the car will run like shit. So don't worry you car isn't screwed up it just is confused....hope this helps...if you have questions email [email protected]
crxtasy is right, the shit that the kit come with is crap, but it's most likely not your map, but rather you tps, the t tap that is included is more likely to cut the tps wire in 2 rather than tap into it, the best bet is to take that t tap off and soder is in place and shrink tube it, i had the same problem back on my dx engine, and that's all it took to fix it...
oh and about the seat, 2dr teg rears fit civic hatchback, and 4dr teg rear fit coupe, as far as 4dr civic's go who knows :)
1 - 14 of 14 Posts
