can someone list everything to cover up when washing the engine bay and supply pics if possible of everything.
thanx
thanx
thats the thing, i wanna know what to cover up, because its really dirty and i want to be able to take it and soak it with cleaner and then spray the shit out of it with a pressure washer!Kinipela said:You should clean with a warm engine at the start. Don't use any attachments on your hose, just let the water run out the end of the hose(it will help keep water from being forced in to electrical components.)
A pressue washer will not get it clean itself, you still have to use some soap and scrubbing. At the least cover any cone style air filter that you have. But using a pressure washer you are asking for trouble. You can use simple green on your engine as nothing has a finish that it is likely to eat away at.BoostedRex said:
you have a 2000 car, i have an 88, how would you have any idea as to what it takes to get my engine bay clean ?munkeysoup said:i just wipe mine down w/ a wet towel and use simple green on the stubborn stuff. thats really all you need to do.
You asked specifically for help in treating your car properly. Then people offer you help and you complain cause they are not giving you the answer you want.BoostedRex said:thats exactly what im trying to avoid. im actually concerned about how i treat my car.
Care to share this super engine cleaner with us all? I'm interested, since my friend has an 89 CRX and could benifit from this scrub free cleaner.BoostedRex said:the cleaner i got will take the grease and stuff off without scrubbing.
and even so, i didn't ask what to use to clean it or if the pressure washer was a good idea, i just asked what to cover up so i could use a pressure washer.
so quit avoiding the question, if you dont know the answer dont post.
Did you not read the 7th post down???BoostedRex said:the cleaner i got will take the grease and stuff off without scrubbing.
