Yeah mine does this, but apparently not as bad. Mine is just damp, no standing H2O. I'm just tired of it doing it.95db8 said:yooo!!! ARE you are talking about water getting on the carpet in front of the passenger seat?
well, thats exactly my problem right now...every times it rains, or i wash my car and spray too much water on the front passenger side, water leaks in...i spent a whole day tearing things apart to see where the leak was coming from, and couldnt find it... im completely stumpled, i did however, stop short from removing the dash completely, and we found out it was not the doors or seals, not the windshield cowl or heater ducts, or any other windshield seals, im hoping its not a small rust hole, cuz the leakage is small, but overnight if it rains, it makes a pool of water in my car. :mad so does anyone out there have an idea :confused
that sounds about right.CRVTEC0WNZJ00 said:Your HVAC System isn't draining the water properly from the airbox most likely a plugged HVAC system, which is the "Air box through which heat and cold air are blown through" There is a drain hole on this because several cars if not all get air from the cowl behind the hood between the windshield, and water goes in there too and also dry leaves etc which can eventually plug the drain hole for water in the HVAC box. Just a possibility though.
that sounds about right. I have the same problem with my car but its only happened like 3 times since ive had the car.CRVTEC0WNZJ00 said:Your HVAC System isn't draining the water properly from the airbox most likely a plugged HVAC system, which is the "Air box through which heat and cold air are blown through" There is a drain hole on this because several cars if not all get air from the cowl behind the hood between the windshield, and water goes in there too and also dry leaves etc which can eventually plug the drain hole for water in the HVAC box. Just a possibility though.
So I need to take off the cowl at the base of the windsheild to get to this? I'll give anything a shot to try and get the car to stop doing this. Is this some thing I'm going to have to ream out or what? Give me as much info as you can about this.....CRVTEC0WNZJ00 said:Your HVAC System isn't draining the water properly from the airbox most likely a plugged HVAC system, which is the "Air box through which heat and cold air are blown through" There is a drain hole on this because several cars if not all get air from the cowl behind the hood between the windshield, and water goes in there too and also dry leaves etc which can eventually plug the drain hole for water in the HVAC box. Just a possibility though.
