hey,
dont know if this was covered before but has anyone stipped there car for track used or drag? if so wat was taken out?? and how light did the car make?? wats the weigh of the 94 accords?
thanxs
when you strip the car, you take out all unecessary items: back seat, carpet, sound proofing, interior trim pieces, the dash, center consol, possibly the ac, power steering, maybe replace glass windows with lexan, passenger seat, door panels, replace body panels with fiberglass, etc. if you were to do all the things listed and then some more you might shave 200-300 lbs. stock 5th gens are rated at little over 2880 lbs curb weight. thats the DX model. LX/EX model weighs from little less than 3000 to little over 3000lbs.
you can possibly get down to around 2400lbs if done fully and properly.
Change the trunk lid, hood, sideskirts, front bumper, rear bumper and fenders to fiberglass or full carbon fiber.
Cut all long bolts to only necessary lengths
Remove cat, put in test pipe
Get ahold of Racing Hart Cp035-R wheels or Volk te-37's for lighter wheels
Strip door panels, all sound deadener, all trunk interior pieces, rear deck, all
speakers including underdash wiring for them, remove dashboard facia, glovebox, a/c material and power steering materials.
Remove headliner and sunroof (install a plug if needed)
Remove one bulb from each corner light, remove high beams headlight bulbs
Remove shiftboot, kneebolster, center console, rear seat, rear deck, all carpeting and passenger seat
And you should have a pretty lightened accord. hahah
Discussion Starter · #6 ·
thanxs guys will do all that and will let u know how much it weighs
