high-pitch noise...kinda like a squeel or something? COuld be a loose belt, perhaps power steering?
And the bolts you took out only hold the cam gear cover...it has nothing to do with the noise.
Are there signs of anything rubbing together? Check the deflection of the belts...you might have to adjust the tensioner bolt to tighten up the slack.
