1 - 17 of 17 Posts
ok people, i need some help, when i make a left turn, or sometimes when i take off real slow, i hear this clicking grinding sound comming from my front left, also when i hit a bump going kinda fast my struts are poping, so my questions, could that sound be coming from the strut? do i need to replace my strut soon? my brother says it sounds like a loose exhaust bolt or somin, could this be it? well any advice is appreciated, im goin the the performance shop next sat, or on my next day off, so i need somin to say to the guy about a diagnostic
many many things.
Blown Strut, Bad spring seat, Something Wrong with the A-arm on that side, wheel bearing cooked. all kinds of things. but as was said more than likely just a toasted CV. have you looked underneath to see if the CV boot is still there and not ripped?
I have the same problem.
It makes thumping noises when i go over bumps.
It really sucks and i don't know what the exact problem is.
Neuspeed race springs w/ stock shocks.
my car has about 50k miles.
I just installed Neuspeed Race springs and since than it started making that noises from the rear.
Like thumping noises like other dude
Wut do need to replace and check?
My car has 105k miles on it and I just had my cv joins replace and it cost $700 to fix..... It was a bitch but I guess my car needed it.:rolleyes:
700 to get ur cv boots replaced? damn a brand new axle costs like 100 and labor should only be like 100-200 for both..so like 300-400 max for both axles replaced. the clicking and turning def sounds like the cv boot is ripped, just get a new axle.
Alright, this may not apply to you, but it may save you a good deal of cash, if it is the problem, who knows.
I have an 87 LX which damn near identically makes the same noise you are describing, almost.
The noise was coming from the front left of the car, I could just swear up and down all day long it was.
I inspected it over and over and could not figure out what the hell was going on, I was afraid a damn wheel was going to pop off, but aside from the noise it seemed to be doing fine.
Not having any money to blow really, I kept postponing and waiting to have it looked at by a mechanic.
I finally made a trip back to my home state where my parents used to own and operate (mechanics themselves) an import garage (20+ years) which specialized in Hondas ever since the first one was sent over to the states. Unfortunately due to profit margins they closed shop a few years back due to extreme competition, but they still service old die-hard customers in their home garage.
I found out that 50% of the time, if you sit your ass on the front left fender and bounce up and down, it would make the same damn noise.
Of course I tried to show my father the noise by bouncing the front left of the car with my ass and hands it wouldn't make the noise, but when I parked later in the same spot I tried again and it made the noise. Go figure. Kinda like smacking an electronic device and it becomes operational again, but not always.
He told me to pop the hood after not seeing anything under the front left of the car that would be making the noise. Everything looked good.
In the front right of the engine bay (FL fender side) there is the casing of the strut tower, likewise of the one on the other side of the engine bay.
There is a black rubber/plastic cap ontop of the casing and he used a flathead screwdriver to pop it off. (might had been screws holding it in place also..I forget in all honesty)
He then told me to bounce the car up and down, so I did.
What we saw was the top of the strut tower not bouncing up and down along with the rythem of the body/chassis. Which is not cool. The strut tower was stationary.
He tightened the bolt ontop holding it in place down to where it should had been, and told me to try it again.
The top of the strut tower afterwards would bounce up and down with the rest of the car, it was tightened/locked in place where it should had been again.
We went out for a test drive and presto, no longer any noise.
The noise of my own description was a "squishy metallic" noise. It wasn't like...KNOCK KNOCK KNOCK. It was a brief continual metallic rubbing squishy noise. The best I can describe it.
It would make the noise going over even the slightest bump in the road. If you were cruising going straight down the freeway, it would not make the noise unless you did some serious turning.
On the other hand, it could be your CV boot has had one too many rocks thrown up at it, and the CV boot has cracked open and is either leaking out its grease or has no grease at all in it now, and will make a similiar noise.
It really pisses me off when I have quirks happen to my Accords, and I can't figure out for the life of me what is going on, and afterwards I find out it should had been totally obvious, if I had inspected a little further.
I also had a CV boot on the front right side of the car replaced later that day, we found that it had been cracked open and was leaking grease, my dad and I up at my grandfathers car garage were suprised it hadn't been metal rubbing on metal by that point, but it wasn't.
All totalled it costed me $63 to get the CV boot replaced, a new rotor, one new front brake pad, transmission fluid changed, oil filter, and a new fill of Mobil 1 Synth.
Aside from warranties, if you can find someone around your area who KNOWS Hondas, and has worked on them for a couple decades, to hell with the majority of the Honda servicemen. Honda will bend you over and make you pay for it.
When I installed my Ground Control Springs my rear suspension was making noise. It turned out that the rear springs were to long and were rubbing against my coil. Maybe you should check the inside of your springs to look for any wear and tear.
· Super Ban-Finger Mod
i too heard a knocking sound and lagged on checking on it. on the way home, the knockig sound got worse and i finally decided to get it fixed the next morning...comming off the freeway, the knocking sound stopped, of course, so did my whole car since the wheel came flying off along with my front left fender. miraculously, nothing else got messed up especially since i landed on my rotor and scraped it for about a foot. anyways, i towed it to the shop a few days later after saving up some money and found out my lug nuts were too loose and/or the wheel studs (where u screw the lug nuts) were just about to break, thus vibrating the wheel left and right making that knocking sound when u hit bumps. i've seen this problem on two other cars already, but theirs were in the rear. jus check if your lugs are torqued correctly...it could save u a lot of money.
OK...I took out the whole shock in the rear and checked everything is ok.
And hoping that noise will go away...
I tightened all the bolts..
bumpstop was cutted by half...
springs were installed right...
But it was still creating thumping....or kinda like grinding noises when i go over bumps.
I am pissed...i don't what is the problem is.
I think my stock shocks are still ok....However i kinda guessing that noise is coming from the top part of the strut.
Where springs and top strut metal plate sits and screw tightens the spring.
I think the rubber round mount is not holding the springs well and spring is hitting the top strut.
If you know what i am talking about or had same experience...just let me know
Thanks sorry for the long post
is it like squeaky knocking?? if so then its ur bushings. mine does that and the bushings got old and ran out of greese. it still does it from time to time but now its okay caus ei put grease in it. if u think its ur struts push that side of the car down hard and let go. if the car bounces more than 3 times then it is, if not then its probably ur bushings or ur cv joint, or maybe even ur axle.
:D that was easily fixed awhile ago:D
the rear sway bar was loosen and creating annoying noise.
Thanks much for help though.
1 - 17 of 17 Posts
