1 - 11 of 11 Posts
they did not have any hondas beyond a 1992. I have a 2000 DX 4-door automatic. is there anything at all I can salvage from a pre 1990 civic?
also, what years and models have the d16y8 engine?
I really don't think so.
This information is available in the forum stickies and faqs.
nothing you would want
read up on information before just posting it up, this info can be found easy, as kommon_sense said, in the stickyies, probably in more than 1 forum on this board...
but in any case its the 96-00 civic EX
A z6; intake manifold, head, exhuast manifold, rear disc brakes. 88-92 injectors.
The real question is: is there anything on your 2000 DX sedan that can be salvaged??? :D
What you ought to be looking for is a complete top end (head, manifold, t/b, injectors) from an automatic D16Y8, along with a 99-00 automatic Y8 ecu, and knock sensor. That will be a really easy swap to do. Just add 4 wires: knock, VTEC solenoid, VTEC pressure, and PTEC pressure ground.
:hehe
Discussion Starter #9
I was there looking for precisely those things, however as I said there were none beyond a 92. I will probably have to try a different yard.
LMAO, hahahahaha!! kommon u always got me crackin up @ your common scence.
your awesome man, haahahah
kommon_sense said:
what pre-90 civic came with a z6?
why would he want a carb or a dpfi manifold?
why would he want a 15yr old head?
what exhaust manifold will work with his current cat setup in his dx/y7?
such old calipers would need a rebuild and 99% sure they won't bolt up on a 92-00 chassis
why?
1 - 11 of 11 Posts
