i would like to know what type of engine should i put in my 96 cx hatch, id like to stay jdm, like a h22a or b18 or b16 i need to know the benefits and diadvantages of each
Its all personal preferance! And it depends on what you plan to do with the car. if you plan to do only drag racing and want a fast car with alot of tourqe go with the H22, the only disadvantage of the H22 is its size and weight and its a more difficult swap! its around 185lbs heavier than your stock motor so plan to do some suspension upgrades!, i have a book saying H22 civics with bolt on have potential for high 12's!...my friend has a 95 civic with an H23 and it moves! If you want something quick maybe for Auto-X and the occasionla drag, go with the B16A or B18C, they are both great engines... or if you want to get really crazy you could get a B18B and turbocharge it!The B18B has one of the strongest stock bottom ends that honda makes and also makes quite a bit of tourqe! its all about personal preferance and budget though! Good Luck
