I just put in Eibach springs Prokit and have all of a sudden started expieriencing problems with my brakes. Every once in a while the pedal justs drops. I found my driver side banjo bolt was loose. Wierd because I never touched my brakes when I put the springs on. But anyway I replaced the gaskets and tightened it back up and bled the hell out of all the wheels. But once or twice a week the pedal still drops. What do you think?
which banjo bolt are you talking about? hows ur brake fluid? is the level fine?
check for leaks and make sure everything is tight.
if there are no external leaks and everything is tight you should bleed the system again just to make sure. start with the wheel thats furthest away from the master cylinder and work your way to the closest.
if the pedal stil goes to the floor once in a while then the master is bad.
you can buy a rebuild kit and do it yourself of you can buy a new one, or one thats been rebuilt already.
