Someone told me that i should get a pully kit. What is a pully ki and what does it do? What will it do to my car?
Performance pulleys are intended to restore lost wheel horsepower by replacing the heavier OEM pulleys either with lightweight pulleys or with pulleys that underdrive your accessories (power steering, alternator).bmzippy2002 said:Someone told me that i should get a pully kit. What is a pully ki and what does it do? What will it do to my car?
What some guys do is get a Marine Deep Cycle battery that has a much higher charge retention. (some auto batteries to consider as alternatives: Exide Select Orbital and Optimal)jocktheglide said:So when you installed the AEM pully set it robs you of power? I mean power as in electricity? Man, so that means you will be draining your battery faster just to install the pulleys. From what I read if your radio system is over 300watts it's a bad idea to have unless you have a spare battery in the trunk or something running your radio. I think i"m still gonna get some pulleys cause it would make my car look nicer.
