What is the maximun RPM for d16z6?
  • No se que es esto
    Votes: 0 0.0%
  • nose que es esto de una poll
    Votes: 0 0.0%
  • Idont know what is this?
    Votes: 0 0.0%
  • Someone please help me out????
    Votes: 1 100.0%
Hello I have a 94 Civic EX (USA spec)with an D16Z6 engine and manual transaxle and the maximun rpm I get out of it is 6500. Is this correct?
No it revs to 7200 rpms.
What could my problem?.....also I think my vtec is not activating. If you have any ideas on where to start to search I would appreciate if you let me know.
Thanks in advance...........
Do you have a check engine light? Are you using the correct ecu and distributor for your motor?
Well, it could be a number of things, like SFF900 said, first ensure you do not have a CEL, if you do, that could be your problem right there, and also be the same reson VTEC does not seem to be or is not engaging.
Now, has this car been torn apart?? Had a motor swap, and brought back to stock?? Maybe you don't have a VTEC ECU, somebody could have sold/traded it for a DX ECU.
Another thing to think of is the stock tach is sometimes off, my tach is off on my EX by about 500-1000rpms and some times more at random. So that could be it as well, check your speed in gears instead of RPMS. Also VTEC is not noticeable on the SOHC you have to be paying really close attention to notice especially if the car is stock.
Good luck!
Discussion Starter #7
Hey, thanks for all of that info. My car is stock engine d16z6,never been swaped and my car has p28 ECU. My check engine light come on and then off when i turn on my car.......What is the CEL and where it goes in my car?
Thanks a lot again.
Thanks a lot again.
If your check engine light is not on when the car is running you dont have any trouble code....
