What is the program to write java?
583 Views 6 Replies 6 Participants Last post by  del_parker
Anyone know what is the best JAVA program?............i want to write and run the program ..........and where can i download for free?
I am using window XP..........and every Java applications are not working............what happen to my PC?
what program am i missing? Do I have to download some software to make JAVA work in my computer?
anyone knows?
thanks
you need to download and install Java Virtual Machine before you can run or view Java application/webpage on ur machine. As for writing Java stuff....you can use TextPad for that. Go to download.com and download it :p
I just download Java virtual machine, Jcreator and Textpad
After I install the Java virtual machine ........i can see things in java in brower
but after I install J-creator and Textpad, I can write program........but i can't run it............why?
am i missing something?
I heard someone told me i have to set something up in my PC to run it? :confused:
thanks anyway :)
You need to install the java virtual machine© Another great programming IDE for java is Borland JBuilder© It was free for a while but I dont know if it still is©
most likely the reason that you cant run it is because it isnt compiled yet, you will need a compiling program, i prefer codewarrior, but i am just used to that from school.
after you write the java code, you'll need to compile it. download the jdk from java.sun.com. they also have a tutorial there that walks you through writing your first java application. or ask. i've been a java developer in the industry for about 5 years now. ;)
thanks anyway :)
after installing textpad and java, goto to configure, preferences, tools, and apply the java compiler, run application, and applet IF they're aren't available already on the tools menu.
