hey guys im gonna drive my car from oregon to LA and im thinking of replacing the timing belt i dont know in what shape it is but i dont want to take any chances so imma turbo my car in a couple of months should i use a honda oem belt or some other brand???
now wheni drive my car hard or when i go to school in the morning and the car is cold the gas pedal sticks and i have to pump it a cuple of times and it comes loose once again what can it be???? :(
hmmmm. it shouldnt be so bad when it warms up. the gas throttle cable is probably just freezing. just use the OEM belt. itll be fine.
also check to see if the throttle cable isnt slightly bent or pinched anywhere. I had a problem with it getting stuck because someone tried to tidy up the bay, and pinched the cable.
i say oem or a good timing belt kit from napa or carquest...one that meets oem requirements
also check for a binding cable or something
yeah it's always better to let your car heat up before any driving. Also i got the Greddy timing belt due to the longer life on it, and it meets OEM stats. I'm guessing it's the cable freezing.....pump it a few times
