you usea ll the mounts that are attached to the chassis.. and you use a 99-00 Si/B16A2 rear and upper tranny brackets.. and the b16 upper breacket (the little L shaped pice that bolts to the block, and unless you wish to put solid poly urithane mounts in there you will need to get the two front lower vibration mounts off a B16 as well.
