Ok, now i have started to work on my car again since i put it away for little over 2 weeks, and im getting irrated with it again!
well, it appears that when its colder outside, the tach will jump around more often, that includes the stock tach and the autometer tach too. Plus my car is running extremely rich, i tried 50 shot again today, in this 45-50 degree cold weather, and the a/f gauge went as far as almost to the lean zone. Which it shouldn't.
Well my question is which OEM FPR from other car will work on my car? Like integra or civic fpr?
The list is long..
TPS
CPS
O2sensor
MAP sensor
Barometric sensor
ECU
FPR
IAT (intake air temp)
Injectors
all the sensor that i listed, would thow a CEL/MIL if they were out of spec, execpt for the FPR, and maybe the injectors and ECU. But i cant figure anything out unless i swap the parts out and try each one to seee which one is faulty. But theres no H22A1 in this town, just me...
ALso i could smell fuel in my engine bay as i opened my hood to hook up my WOT switch for my nitrous. But i couldnt find a leak, its more like a vapor smell, not like a leaking fuel smell.
I have shorten down the list to FPR, ECU, Injectors, and igniton control module.
I need suggestions, and which fpr would work on my car..
Thanks
The list is long..
TPS
CPS
O2sensor
MAP sensor
Barometric sensor
ECU
FPR
Injectors
Thanks
