I was curious if there are some parts that are interchangable between these motors. Specifically, Im interested to know if the distributor, throttle body, valves, ECU, and injectors. I know the injectors are the same style, but I am unsure as to the flow rates on them...being that the h23 is 30hp stronger from the factory...
As you might have guessed, I have found a h23a for a fair price but it has bent valves from someone screwing around with the cam gears too much. What could possibly be affected besides the valves themselves? Is this something I even want to get into?
Thanks.
Thanks.
