I have a stock 1993 Del Sol Si and the radiator is cracked on the top near the radiator cap. I am leaking fluid from the crack and so I need to replace the thing. So, what do you all recommend for a replacement? I am currently stock but plan on running a modified D16Z6 with a block guard, weisco pistons, arp studs/bolts, and a turbo.
So, is there a good choice for a radiator? I keep looking at the Koyo all aluminum one, the mishimoto one, godspeed, and even stock. Is there really going to be much difference between the stock unit and these more expensive alternatives?
