I just had the stock cam on my 86 accord LX ground to a spec of 272 degrees for the intake 292 for the exhaust seat to seat, with the intake lift at .402 and the exhaust at .413. I installed everything and double checked all the vacuum lines , bought a new fuel pump and new wires and plugs and the bitch wont start! I've tried everything! The cam timing is dead on point, the firing order 1-3-4-2 is correct! I look at the gas level window and its no where near the middle. When I crank it it sounds funny cause all i have attached are the headers but it doesnt even sound like its trying to ingite the mixture. I was reading about cams and it said that the wider the lobe separation the less vacuum anyone think that could be causing it to not start?
