I might be buying a jdm f22b with ecu for about 600 bucks! Would it be stupid to put another f22 tranny to it, or should i look at a h23 tranny? Does the h23 rev higher, what are the advantages?
f22 will work. depends what ur gonan do. are you gonna boost this motor? if so stick with the f22 trans
Super Ban-Finger Mod
94honda said:
Why stick with the f22 if im gonna boost, can't the h23 tranny hold up to boost?
because the h23 is geared shorter than the f22
94honda said:
Well the h23 would be quicker then the f22 right, shorter gears!
if you want to run NA, then yes, h23 is good. but the way the powerband is on the f22 and if you want to be boosted, then shorter isn't necessarily better.
