I'm going to buy a 1992-95 civic for my project car and was wondering what year of a gsr motor to put in it?? does it drop right in? need additional motor mounts??
OBD-I takes to mods better though. Just a thought.94gsrsol said:OBD2, I recommend simply because the motors are newer. Do you plan to build it while it's out? If so it doesn't really matter what year it is. A good idea for your ecu is to send it out and put a spoon program or mugen program for the obd switch, it's inexpensive and saves from a wiring mess. Just a thought though. Have fun doing the swap and good luck.
it does not matter if its obd1 or obd2. if its obd1 you leave it the way it is and if for f u get an obd2 gsr motor and you want to put it in a 94 civic it will be a pain in the as to keep it obd2. you will have to change the whole harness. something you dont want to do. so to make things easier you change the distributor to an obd1 and you run a 94-95 integra gsr ecu.94gsrsol said:OBD2, I recommend simply because the motors are newer. Do you plan to build it while it's out? If so it doesn't really matter what year it is. A good idea for your ecu is to send it out and put a spoon program or mugen program for the obd switch, it's inexpensive and saves from a wiring mess. Just a thought though. Have fun doing the swap and good luck.
