1 - 8 of 8 Posts
Well i got a free b20 block with some fucked up pistons and some scratches on the clyinder wall so im gonna get the block overbored to a 84.5 or maybe even 85 which ever safe with the stock sleeves...i know the b20 sleeves are not the strong but remember this setup is basicly a stock NA b20 with some high comp pistons, street camshafts (either some 403s or some exospeed regrinds), Skunk2 IM and the regular bolt-ons. For my trans setup im getting a hydro GSR trans with exedy oem clutch and a ITR flywheel. So wutcha guys think about the stock sleeves being bored out a little...is it safe? and wutcha guys think about the CTR N1 pulley? my goals are to make around 150-160whp/130-145wtq...you think its possible with those mods?
one do not buy regrinds.... Second, i would sleeve that block if you go anymore then 1mm over stock bore, if you go .5mm you should fine, with out sleeving...
Re: Re: What you think of my setup? (NA B20)
Whats the reason for not using regrinds?
Please explain.
I have never had a problem with regrinds
b20a, b20b/z?
which one...
it makes a big difference...
if you're talking about the b20a, talk to some people on preludepower.com, and you'll find out the limits of the motor
its like buying a car that has had mass body work done....
they have to add the cam and then re-grind it...
it also throws something off in the cam, i can not think of the name of for the life of me...
Buck up and buy a cam that has been gound from a blank...
sorry but that doesnt make sense. Many of the high output motors out there are using cams that are grinds from stock cams. Of course a new blank is pretty good itself, but it doesnt make a Grind cam any inferior as far as making power.
1 - 8 of 8 Posts
