1 - 11 of 11 Posts
If I am not mistaken, fuel pressure on a stock b18c1 is between 40-44 psi. You can probably bump that up without having too much trouble. Do you have an A/F ratio gauge yet? If not, you maybe want to invest in one. JMO!:)
People need to clarify if you are reading off vacuum, or on .....
The Type R off vacuum is between 50-52 psi, and that is a very rich fuel map.
A modded GS-R should be fine at about 46-48 off vacuum, and that is all the way up to R cam swaps.
Off vacuum factory is between 48-55 psi.
On vacuum factory is between 39-46 psi.
i have the GSR head (ported & polished) on a LS block...last time i checked not even two weeks now..
my fuel pressure was 47psi...
i am takin for a 500 mile ride, them i will check the plugs and see if i am running rich or lean///
later
Definately need air fuel gauge
An air fuel gauge could mean the life of your motor, I don't think your going to be running to lean but running rich isn't exactly good either. I would infest in a step up on injectors too if you have the pressure you might as well follow up on some volume.:cool:
Yeah, but you need to qualify that as a WIDE BAND O2 GAUGE ..... the other one's are crap (i.e. Autometer, Greddy, etc.)
Expect to pay in the $300+ range for a REAL air/fuel gauge.
1 - 11 of 11 Posts
