Physics....
The physics favor lower compression. If you think about it, it makes perfect sense. Lets think of two theoretical turbo motors with the same displacement. Now one is low compression and one is high compression. Both have the same EFFECTIVE or final compression ratio. That is, once the piston has completed its compression stroke, both motors have the same volume of air. Which will make more hp?
The lower compresion motor has the advantage. In the high compression motor, more of the compression is done in the cylinder/combustion chamber through the motion of the piston. This causes heat. Lots of it. In the lower compression motor, the same volume of air is moved, but more of it is compressed and put into the cumbustion chamber via the turbo. This results in a cooler initial charge because the air is not as hot. It has been compressed more effciently (slowly) and has been intercooled before going into the cylinder. Cooler initial charge for the same volume = more hp. Can't argue with physics.
Now, for a street car, there is a trade-off. The lower the compression, the less hp before you are on boost. But, you get more peak hp. Its all about balance in street motors. A turbo race motor will have really low compression because they never really run it off boost, except to stage. A daily driver will want higher compression so that the car is not a complete pig in traffic.
