I need to know what is the best engine swap for a 91 hatch back,some say b16a,how about a integ type R MOTOR,also what is the best platform for this vehicle meaning easy way to go. thanks
with crx's and 4th gen civics, there is a lot more work involved for b16 swaps. Those normally run about $2,500 for parts and labor. $500 for a swap? Shoo, that's how much I paid for the motor and cluch alone. If you can do it for $500, then more power to ya, but I find that hard to believe. I paid $350 more for labor(friend did the swap), then the rest were for parts, such as belts, fluids, injector/resistor box, vtec/fuel controller, a/f gauge, '89 integ ecu. I highly doubt anyone on here would agree with your $1,550 estimate on doing a complete b16swap into an EF civic/crx.b16ahybrid said:Personally if i were to do a sohc swap into a civic/crx i wouldn't pay more then $500 for it (no offense to you) but at $1,200 you could have spent a little more and got a dohc b16a.I've seen complete swaps including engine,tranny,ecu,mounts,axles and all components (alternator,starter,sensors,etc) for about $1,550.With the b16a you would have had 158hp vs the 125hp and 111 lbs of tq vs the 105lbs.Plus an engine with a lot more potential.
Probably the best swap for that car would be either the dohc zc or the b16a.The b18a/b, and b18c1/5 would also all fit but you will run into clearance issues with the lower cross member and oil pan vs concrete wars..I've seen the b18's in crx's but from what i've heard you are limited to how much you can lower the car if at all without doing some modifications.So with that said i think the b16a is the best bang for the money plus the jdm civic/crx came with that engine stock
with crx's and 4th gen civics, there is a lot more work involved for b16 swaps. Those normally run about $2,500 for parts and labor. $500 for a swap? Shoo, that's how much I paid for the d16y8 motor and cluch alone(i used my crx tranny and distributor). And for the ZC's, I usually see ZC motors with distributor and transmission for around $700. If you can do it for $500, then more power to ya, but I find that hard to believe. I paid $350 more for labor(friend did the swap), then the rest were for parts, such as belts, fluids, injector/resistor box, vtec/fuel controller, a/f gauge, '89 integ ecu.b16ahybrid said:Personally if i were to do a sohc swap into a civic/crx i wouldn't pay more then $500 for it (no offense to you) but at $1,200 you could have spent a little more and got a dohc b16a.I've seen complete swaps including engine,tranny,ecu,mounts,axles and all components (alternator,starter,sensors,etc) for about $1,550.With the b16a you would have had 158hp vs the 125hp and 111 lbs of tq vs the 105lbs.Plus an engine with a lot more potential.
Droping a b16a into a 4th gen chassis isn't that hard.They do make mount kits for that car and engine that run about $450 so that makes the swap a lot easier plus in japan some of the civics/crx's came with a b16a so making it fit isn't to involved.I have seen complete b16a swaps (including mounts,engine,tranny,ecu,axles,etc) for $1,550 and $1,000 without the axles and mounts.Either way you looking at about $1,600-$1,800 installed with new belts,water pump,etc.If you do the work yourself it will save you a great deal of money.Your $2,500 estimate was more then my second gen b16a (sir2) swap complete i only paid $2,100 and that was with a gs-r tranny.Although my price did end up going up because i did a complete rebuild along with a new act clutch.NawTeeCRX said:
