most of these ebay chips will make you run rich, advance your timing to who know's where, and disables CEL's. if this sounds like fun to you then go right ahead.revharder said:Ok,so they suck or don't work?
My friend had one on his 97 LS it made a difference but he is paying for it now cuz he floated a valve from taking it past redline so many times wit that chip in. I wouldnt recomend buying one...revharder said:You hear anything good about them with basic setup?Just wondering, because they go for really cheap. 94 Acura integra gsr obd1
it makes the ecu think the incoming air is colder than it actually is, in turn dumping in more fuel.amctmg said:that little resistor thing they sell on ebay you can buy in packages of 6 for a dollar at a electronics store and they essentially lie to the ecu as to what temperature the air is going into the engine. I don't remember if they tell it hot or cold or what the effect is but you do notice a small difference in power, atleast it feels like it and it seems to smooth out the power. However I used to use it at the strip and my best times were when I was not using it.
