Discussion Starter · #1 · (Edited)
i have a 98 prelude sh with 17" speedy lite8 rims and no supension work at all the wheel gap in the in the back is 2.5" and the wheel gap in front is 1.75" is this normal, because i want to lower my car but i want to know if i need to fix anything first. ill put up pics soon
:confused
What size are your rims...
13"......actually, depending on your rim/tire size, that could be very normal....try the search feature for your question, you will get hella flamed otherwise....
Dr Mabe said:
i have a 98 prelude sh with speedy lite8 rims and no supension work at all the wheel gap in the in the back is 2.5" and the wheel gap in front is 1.75" is this normal, because i want to lower my car but i want to know if i need to fix anything first. ill put up pics soon
Buy a tein coilover setup and set the darn thing how you want it. Problem solved. :D
Discussion Starter · #5 ·
all the lowering kits that ive seen lower the car more in the front that in the back, i want my car to have a even wheel gap all arround preferably about a 1/3 inch, the tein setup is way to exspensive for me :D
go with a coilover setup.. tein preferable. you can adjust ride height, whereas with a spring/strut combo your stuck with what you have, plus coilovers are a better bang for your buck. spend your money right the first time.
