Is the universal taper on wheel nuts, or the tapered seat on the wheel 60 degrees?
Also, if you look at Spoon's aluminium wheel nut lineup:,
the gunmetal grey nut has a much "shorter" taper that the red or blue ones. Will this "shorter" taper still fit & work the same as the "longer" tapered wheel nuts?
