I just got new tires on my 2004 CR-V, and the mechanic said, "You really need new front brakes, like right now." That surprised me, because I check the lining thickness pretty regularly. When I got the car home, I checked again (very easy to do on the CR-V), and the thinnest lining was 3.3 mm. The manual says the service limit is 1.6 mm, so I figure I'm fine.
The only reason I post this is that I saw a tool on eBay for measuring the thickness, and the tool implies that 2mm and 3mm is worn out, and anything 6mm and under is "Dangerous".
Is there any reason I shouldn't wait until the lining is 2mm or so before changing them?
