My car is a 92 si. I bought some brembo cross drilled rotors for my car and they didn't fit. I measured the stock rotor, it was 9.5". The brembos were 10.3". I did some research, and found out that 96+ Civic EXs came with 10.3" rotors and do 94+ Integras. And after some more research, I discovered that it is possible to make the 10.3" rotors fit by using steering knuckles and calipers from either the 94+ Integra or 96+Civic EX. I picked up those parts from a local honda salvage yard for $120. The front driver side assembly was from a 95 integra and consisted of the caliper,knuckle and spindle amoungst other things. Passenger side was the same deal, except that the whole assembly was from a 94 integra. To my horror, both spindles had bad bearings. $106 dollars later, the new bearings were pressed in, and everything was put back with the new components. The rotors looked great sitting behind my 16's. Messing with the suspension, I noticed that I threw the camber and toe settings all out of whack. Since I have an Ingalls camber kit in the front, I tried to set the camber back to stock settings. The driver side looked OK, but the passenger side was were the problem was. I bottomed out the kit trying to set the camber back to normal. Most people have a problem with too much negative camber, but with me its opposite. I have zero camber. People that know about camber, know that hondas have about 0.5 degrees negative camber. On top of that, passenger side now has about 5mm more offset then the driver side.
I'm guessing that I have a bad spindle on the passenger side, but I'm not completely sure. If anyone knows what my problem might be or have any comments please reply.
