skunk2 test pipe
If you're looking at replacing your stock cat and getting something which allows alot more airflow then i recomend Skunk2's test pipe. I have one and am very happy with it..It has a 2.5'' outlet on both sides so it should fit the application your dealing with. It also adds a few HP.
guys...all of your suggestions are for test pipes...he wants a cat.
magnaflow/carsound makes 2.5'' high flow cat converters...you can find them on ebay
re:
A high flow cat is basically the same thing as a test pipe. With a higher flow cat it will burn right through your o2 sensors more often so you have to get a o2 sensor simulator to trick your ecu.
