I'm still trying to decide which actual car and model I should use for the foundation of my project. I.E. 1996-2000 dx, lx, hatch...... I can't decide. What would you recommend? Please list the strengths and weaknesses of each. Thank you!
well.. lx and dx are non-vtec, ex's have vtec, but you can always do a swap, dx's tend to be bottom of the line as far as luxarys go.dano104 said:I'm still trying to decide which actual car and model I should use for the foundation of my project. I.E. 1996-2000 dx, lx, hatch...... I can't decide. What would you recommend? Please list the strengths and weaknesses of each. Thank you!
just by color.....that can be changed easily....i redded mine out so the only thing of a different color are the rev. lightssnozepp147 said:also the taillights
LOL. Why four doors? Isn't it just more weight?FERIO_SiR said:96-98 Ex four door then turbo
well if u can find an si go for that better stock enginedano104 said:I'm still trying to decide which actual car and model I should use for the foundation of my project. I.E. 1996-2000 dx, lx, hatch...... I can't decide. What would you recommend? Please list the strengths and weaknesses of each. Thank you!
It is more weight, but that is why you compensate with a turbo. I just like the four doors the best.dano104 said:LOL. Why four doors? Isn't it just more weight?
Yeah I know I'll have to boost what ever I build..... My tastes are more along the lines of auto cross more than drag. My overall plan will be to build a 250HP+ car that handles like it is on rails.nismoboi said:What are you planning to do with the car? DD? Auto cross? Drag? There's not much of a difference, depending if you like a 4 door, 2 door, or 3 door... you're not going to get much performance wise from a sohc without boosting it... The front end changed in 99...
The hatch only came in VX, CX, and DX. That should make your decision easier. If you want to aurocross, then get an Integra. A swap or turbo will screw you over class-wise. Do it and you WILL be competing against high horsepower cars that handle like they are on rails. If you want to compete, then get and Integra, MR2, or Miata. If you want a Civic, then go all out with a swapped lightweight '88 to '91.dano104 said:Yeah I know I'll have to boost what ever I build..... My tastes are more along the lines of auto cross more than drag. My overall plan will be to build a 250HP+ car that handles like it is on rails.
Autocross is just more my driving style, more than straightline drag performance anyway. I won't be competing in autocross events. I just want to build a fun, fast, suprising car. Thanks for the help!flyingtoaster said:The hatch only came in VX, CX, and DX. That should make your decision easier. If you want to aurocross, then get an Integra. A swap or turbo will screw you over class-wise. Do it and you WILL be competing against high horsepower cars that handle like they are on rails. If you want to compete, then get and Integra, MR2, or Miata. If you want a Civic, then go all out with a swapped lightweight '88 to '91.
You should be thinking about whether you want an EF ('88 to '91), an EG ('92 to '95), or an EK ('96 to '00).dano104 said:Autocross is just more my driving style, more than straightline drag performance anyway. I won't be competing in autocross events. I just want to build a fun, fast, suprising car. Thanks for the help!
EG or EK sounds like it would fit the bill, emission laws here are pretty lax, if non-existent. More likely an EK because I have no body work skills at all, I'm just good with a wrench, and anything mechanical.flyingtoaster said:You should be thinking about whether you want an EF ('88 to '91), an EG ('92 to '95), or an EK ('96 to '00).
The EF is 150 to 200lbs ligther than a similarly equipped EG, but the only B series that will fit without special mounts is the first gen B16A. An EG is a little heavier, but any B series will swap right into it, and most Integra parts can be swapped over as well (suspension, dash). The EK is only 50lbs heavier than the EG and any B series engine will fit, but you will need an expensive OBD-II motor depending on emissions laws.
Well, you're just as likely to find an EG hatch with no dings, just because they are much more plentiful than EK hatches. And you'd be suprised how many EFs are in perfect bodily condition.dano104 said:EG or EK sounds like it would fit the bill, emission laws here are pretty lax, if non-existent. More likely an EK because I have no body work skills at all, I'm just good with a wrench, and anything mechanical.
