Alright. So I'm looking on which direction I should go on an ls/vtec. Right now I'm sitting with a stock ls, so nothing has been done yet. Just wondering which direction I should go in. High compression all-motor setup or a turbo setup.
B16A head on B18B block, TiTek adjustable cam gears, TODA B18C timing belt, titanium valves and retainers, Supertech valves, NGK 8mm spark plug wires, Pulstar spark plugs, BLOX intake manifold w/ 70mm throttlebody, Benen fuel rail, SARD fuel pressure regulator, AEM fuel filter, 255Lph fuel pump, Hondata intake gasket, B18B crankshaft, Unorthedox Racing pulleys, CTR N1crack pulley, forged LS rods, ARP head and rod studs, and a mild port and polish.
N/A - CTR intake cam, ITR exhaust cam, 310cc injectors, Comptech intake w/ icebox, mugen header, CTR pistons, and 98 spec ITR tranny. Aiming for 200+whp.
Turbo - Skunk2 Turbo 2+ cams, 440cc injectors, full-race top mount gt turbo kit (gt28rs), forged LS piston, and GSR tranny. Aiming for 250 to 300whp.
I'm not sure on which route to go. And I'm not looking to start arguments between which is better because I know the pros and cons of both. Just advice on what would be the best daily and weekend track car.
Any ideas on the better route? And should I get the block sleeved or will the stock sleeves hold up for my power goals? I'm not looking for anything faster, thats what sportbikes are for. Lol.
