Waste of money. Here's why: The ball bearing turbo that you are paying a lot of money for will not make a difference. If we were talking about a T88 vs a ball bearing T88...then yeah, but these turbos that go on the SOHC are so small, they spool up fast as shit anyway. You don't need a ball bearing turbo that size...it already spools up fast as hell. Also, that A'pex Skyline or Silvia core intercooler, however fucking awesome it may look, is NOT matched to that turbocharger. The turbo that comes with the kit does not flow enough cfm to fill that intercooler effectively, and you will suffer from pressure drop.SiRSoL said:What about the apexi turbo kit for the sohc???
That is the kit I am shooting for but sure it might me a little pricy but I know where I can get the whole thing for about 3000 (with the big a$$ gt-spec intercooler) I have seen a guys set up with this kit and its freakin awsome. Ball bearing turbo spools so much faster. just my 2 cents.![]()
Also, you just can't beat the GReddy price ($1490 - me), and the intercooler is a little over $600 I think, so you are paying just over $2000. With a budget of $3500, you can have all of your bases covered, turbo, intercooler, ignition, fuel, and tuning. You can't go wrong.
The apexi turbo kit is also 50 state legal.oneslwcivic said:Another thing about the greddy kit that is nice is it is 50 state legal.
UndaRated said:Hey sup Mat, if you decide to drop in that d16 motor, that'll make my day =). Hey, quick question, how many lbs did you boost your coupe when you had the d16 and sohc motor? and what did you do you achieve that? Im, talking about fuel and ignition wise. ANd was your motor stock? Any headgasket or rebuild for bottom end? I have the GReddy Blue box which provides ample fuel up to about 9lbs, my A/F goes to stoich at 9. My motor craves boost soo much, but im a lil hestitant to boost it higher than that. I get no detonation at 8lbs so i know the lil d series motor can handle more. It's the most under rated motor in the import scene, hence my username =) O, BTW, i got stock injectors, fuel pump, and ignition.
