Well, you have to make a decision. Which is more important to you, looks? Or ride quality/comfort?
Since you are going with a 40series tire, you don't have a lot of sidewall and the ride quality is only going to get worse when you lower it. The lower you go (usually meaning higher spring rate), the worse it will get.
Anyways, the H&R sports should close up the gap in the rear, and reduce the gap in the front. However I am not sure if it will lower the front as much as you would like.
