I just bought a Zalman CNPS9500 LED....I was going to go with a water setup but to do it right it costs too much.TSXmike said:id like to see your setups and what you use... im starting to shop around for ideas for my next/current build... its time to make this 3500+ work for the money i spent on it...
gurusan said:I just bought a Zalman CNPS9500 LED....
Hold off until July 24th... AMD Dual Core prices should be dropping BIGTIME due to Conroe's release. Expect close to 50% on the lower end. The X2 3800+ is going to be $165.TSXmike said:same cooler ive got... but not getting the overclocks id like to get with my 3500+
but... as soon as my card is paid off that opty165 will be mine! 2.7ghz... here i come!
What kind of motherboard do you have? What setttings have you used?TSXmike said:same cooler ive got... but not getting the overclocks id like to get with my 3500+
gurusan said:Well something's not right. You should be able to OC it a bit more than that.
And your voltage is way high. It should be 1.4 stock and running 1.6vcore and above isn't a good idea with air cooling only.
I suggest you try again.
It's probably your memory....try bumping the vdimm up .1 or .2
And your HT should always stay closest to 1000....so I might try setting the HT multiplier to 4x.
and since you have normal kingston value ram try to keep it running close to stock speeds (assuming it's 200mhz/DDR400)
So try running a memory divider
gurusan said:your 3500 is a venice right?
If so then it should be 1.4 stock. Sometimes the motherboard comes with messed up settings.
gurusan said:oh!!! socket 754!!! my bad.
But still...you should be able to oc at least 200mhz.
Or maybe you just got a dud?
that's a monster. as long as your rooms ambient temp isnt high (above 75F) & it's seated right w/ some good thermal compound you should get great OCs.gurusan said:I just bought a Zalman CNPS9500 LED....I was going to go with a water setup but to do it right it costs too much.
And I just bought a 3700+ with 1mb cache...and i did some research on the stepping and people have hit 3ghz on air with this stepping....so I'm hopeful.
I'll have a CPU faster than an fx-57 for $130!!
