ok boosting a b18c i feel like im running rich on idle and start running lean in higher boost.... idle is at 10 and 8k is at 13 and im running 93... what are the right numbers should i be at? someone hook me up with some numbers i cant find any write ups on this....
Turbo AFR should be 11.5-11.8 WOT
Idle doesn't matter, ideally you should have it as close to 14.7 as possible, but if its leaner or richer, it wont effect anything. Same with the partial throttle maps.. some cars can go as lean as 16 AFR or leaner, without breaking up on the hwy..
If you dont know these simple things, you should really either be researching more or bring it to someone who knows a bit more then you do. I'd hate to see you melt a piston because you're too lean.
