I have turbo b18c1 in my 99 civic, and i keep seeing oil (not alot) just enough to coat the engine id pad and bor code on the tranny. its coming from the area were the metal head gasket is at that corner. Anybody have a similar leak and an answer?
yeah, i had a similair problem... i had noticed that the car was using a slightly more than normal amount of oil, and then later a little bit of coolant... in my case, and probably yours, it's the head gasket (maybe not blown but probably worn)... too bad it's such a bitch to replace. :noo
same problem for me! i will post pics.
