supercivic18 said:
Little mikey,
my wheel offset is 40s. Do you think is should be fine?
well, seeing as how i have no real personal experience with 215 tire on a rim with a 40 offset i can't be 100% sure, but i would say you are going to have some slight rubbing problems. but you should be able to fix by:
1) remove the fender well lining
2) roll the fenders
and that about all you can do. i just ordered a set of 18x7.5 rims (44 offset) with 215/35/18 tires. i shouldn't have any problems with rubbing except for maybe a little on the inside of the tire and the wheel well when my wheels are at full lock. i cannot stress enough how important it is to get the proper offset when buying a rim/tire combo.
optimal offset for a civic with 17x7 is 42 offset. i had 17x7 with 205/40/17 tires on my hatch for 9 months and i was dropped 2.25" at all four corners and i didn't have any rubbing at all, even with full load of passengers.
with a 40 offset your wheel is going to stick out from the hub a little bit more and with the wider tire you may experience some rubbing. i hoped this helped a little.
~little mikey
